I picked up the HS70 at Best Buy today and my friends on discord say my microphone is quiet and muffled. I tried adjusting the recording device settings on windows but its already at 100%. However, when I speak, windows barely picks up the microphone. I cant find any settings in Corsair iCUE that can change the voice settings other than the microphone slider which is also at 100%. There is also white noise in the background that is noticeable. I believe the mic audio is being compressed.
thanks
https://linustechtips.com/topic/935401-hs70-problems/
  • 1 month later...
I had that same problem with my HS50. All my friends were saying I sounded muffled and quiet. And, as unprofessional sounds, I solved the problem by heavily blowing into my microphone. After doing that a couple of times and rejoining my discord call, they were all surprised because I was suddenly crystal clear.
Gaming PC: i7-6700k@4.6GHz w/ Cooler Master ML240L | Aorus Z270X-Gaming 5 | 32GB (4x8) Corsair Vengeance LED DDR4 3200 | Aorus GTX 1080 |  Samsung 970 Evo 2TB + Samsung 860 Evo 250GB + Adata SU800 512 GB + Teamgroup CX 1TB + Seagate External 8TB | Aorus AC300W Case | Corsair VS650 650W 80+ White
Peripherals: Red Dragon K555 INDRAH | Razer Basilisk Ultimate | Corsair HS70 Pro Wireless | MSI Optix MAG341CQ 34" (3440x1440p/100hz/G-SYNC), Naxa 43" (4k/60hz)
Other Tech: PS5 | Nintendo Switch | Oculus Rift | iPhone 12 Pro Max 256GB | iPad Pro 10.5in 64GB
https://linustechtips.com/topic/935401-hs70-problems/#findComment-11593371
