Yes. The brand of RAM doesn't matter. Go ahead!
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/935250-ram-help/#findComment-11421230
-Moved to CPUs, Motherboards, and Memory-
Yes, you can use different brand memory sticks as long as they're the same type. You can't mix DDR3 and DDR4. Note that if you have different speed sticks, then all RAM will default to run at the slowest speed. So for example, if you have a stick of DDR4-2666 and one stick of DDR4-2400, all the RAM will run at DDR4-2400 speed.
https://linustechtips.com/topic/935250-ram-help/#findComment-11421231
Here is what he currently has https://www.amazon.co.uk/HyperX-HX424C15FB2K2-16-FURY-Black/dp/B01D8U2B8W 2x8gb sticks
Could we put this in the system also to make up 32gb? >
https://www.ebay.co.uk/itm/Corsair-Vengeance-RGB-16-GB-2-x-8-GB-DDR4-2666MHz-Memory-Brand-New/282983678007?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D50545%26meid%3D6cd6ab4ce5a94e9f8ae465c2f041a424%26pid%3D100005%26rk%3D5%26rkt%3D12%26sd%3D292042437545%26itm%3D282983678007&_trksid=p2047675.c100005.m1851
https://linustechtips.com/topic/935250-ram-help/#findComment-11421371
https://linustechtips.com/topic/935250-ram-help/#findComment-11421429
