My game was fine all day. I logged on and noticed that it was slow. I looked to the top left and saw it locked to 30FPS. I reset my video settings because I had no idea what was wrong. I noticed that the resolution was showing 3840(30) rather than 3840(60), so I tried to change it.
The option wasn't there.
What do I do?
https://linustechtips.com/topic/934966-overwatch-settings-randomly-messed-up/
You often have to actually edit files when the right resolution isn't showing up. Look it up and see if you can locate the settings file for Overwatch.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
