Games running slower than expected
Solved by DigitalRiot28,
1 minute ago, General Winter said:nice (i have no idea how to disable cores but sounds like you're better now)
Basicly ive been reading on the TH forum (http://www.tomshardware.com/answers/id-3649717/windows-recognizing-cores-ryzen-1600.html) that someone was also running Ryzen master module and suddently 3 of his 6 cores and threads were disabled. It was do to RMM overwriting the bios. I immediately disabled it and used this command prompt (bcdedit/deletevaue numproc) and restarted my computer. It fixed most (or all i hope) problems i had and so far so good. Next time you want to overclock you Ryzen CPU i suggest overclocking with the bios.
