Buy a used Dell optiplex off of ebay with a decent CPU and throw in a used graphics card and SSD.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/933236-i-need-help-planning/#findComment-11401592
5 minutes ago, Jam_Jam_4400 said:
yeah i don't mind used hardware as long as it works and i don't get scammed
ok. you'd be surprised what you can get for that money on the used market.
do you do anything else besides gaming?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/933236-i-need-help-planning/#findComment-11401647
Just now, Jam_Jam_4400 said:
Browsing web, streaming vids and i suppose i would prob want to get into mod creation
mod creation i know nothing about, so i don't know what specs you'd need for that...
i assume you're in the UK.. i don't know a lot about the used market there. can you look up what a 2600K with 16gb of ram, a decent board and a decent PSU costs over there? that'll give me a point of reference.
She/Her
https://linustechtips.com/topic/933236-i-need-help-planning/#findComment-11401677
£350
https://linustechtips.com/topic/933236-i-need-help-planning/#findComment-11401688
£350
ok good. those cost about €500/600 here.
basically, check the requirements of the games you play and the mods you use, and then start looking from there.
something to keep in mind, a build at this budget, even used, won't play everything on very high settings. one of the best price/performance cpu's, the 2600K, is around 40% slower than a 7700K: http://cpu.userbenchmark.com/Compare/Intel-Core-i7-7700K-vs-Intel-Core-i7-2600K/3647vs621
video cards age even faster. i'm quite knowledgeable about old and used hardware, so if you find a system you can always ask me if it's a good deal.
i can't give you specific advice because i'm not familiar with either of the games you mentioned, and i don't know what's available locally where you live. you said you were afraid of getting scammed, so going to pick stuff up is your best bet because most of the time you can then test stuff before you buy it.
She/Her
https://linustechtips.com/topic/933236-i-need-help-planning/#findComment-11401711
Thanks
https://linustechtips.com/topic/933236-i-need-help-planning/#findComment-11401720
1 minute ago, Jam_Jam_4400 said:
Thanks
no problem.
remember you can use sites like userbenchmark to compare cpu's, and i recommend https://ark.intel.com/ for comparing intel cpu's. quite often you'll get a listing for a cpu with just the model number. if you look it up there it'll tell you everything. the year of release, socket, architecture etc.
She/Her
https://linustechtips.com/topic/933236-i-need-help-planning/#findComment-11401730
5 hours ago, Jam_Jam_4400 said:
Hey I need help planning for a gaming pc
I will be playing games like FO4 and GTA V (Both heavily modded)
Budget is around £300 - £400
need os/monitor/peripherals?
https://linustechtips.com/topic/933236-i-need-help-planning/#findComment-11402515
