Hello anyone willing to help,
I currently have a gtx 950 gpu (kinda lame, I know) and a friend of mine with identical one can bring me his which is no longer in use.
I was wondering how do I start? I looked a little online realizing I need an "SLI bridge" and enough ram for that.
peripherals (that I believe are necessary):
GTX 950 3gb
8 gb of ram
Appreciate any help!
https://linustechtips.com/topic/932734-need-help-setting-up-another-gpu/
You can do SLI with 8gb ram so that's fine.
Make sure you buy the right length SLI bridge if it's a solid one(if its too short or long it wont work) or if you buy a cable style one, just make sure its not too short.
1 minute ago, RKRiley said:
You can't SLI 950's.
Yea you can. Maxwell times were strange times :D
CPU: i7 6950X  |  Motherboard: Asus Rampage V ed. 10  |  RAM: 32 GB Corsair Dominator Platinum Special Edition 3200 MHz (CL14)  |  GPUs: 2x Asus GTX 1080ti SLI
Storage: Samsung 960 EVO 1 TB M.2 NVME  |  PSU: In Win SIV 1065W
Cooling: Custom LC 2 x 360mm EK Radiators | EK D5 Pump | EK 250 Reservoir | EK RVE10 Monoblock | EK GPU Blocks & Backplates | Alphacool Fittings & Connectors | Alphacool Glass Tubing
Case: In Win Tou 2.0  |  Display: Alienware AW3418DW  |  Sound: Woo Audio WA8 Eclipse + Focal Utopia Headphones
Thank you!
Do you know if it will have trouble temperature wise?
6 minutes ago, TheMeowOne said:
Well, I thought that I might not have enough ram in order to handle an extra gpu.
That video says absolutely nothing about your system RAM ;-)
It depends. What is your case, how many fans and what kind of version of 950 do you have and will be getting?
I have a Nvidia geforce GTX950 OC 2gb gigabyte gpu and Alpine 11 rev2 arctic cooling fan
Thank you in advance
I was more interested in your case than CPU fan.
I'd expect the upper card to run in the ballpark of 80-85c and the lower around 70-75c. Unless you have a case with side fan that can feed fresh air to them - then expect it to be about 5c lower or something around that.
If you have a case with terrible airflow then you may cook the upper card.
It's a cooler master K282, I don't have any other fans other than the one I mentioned.
Are there other necessary things to get besides the bridge?
As you can probably tell I'm pretty bad at that kinda.
Once again thanks for your help.
