everything requires maintenance with a computer. but yes
Setup:
 AMD Ryzen 5 1600
Sapphire AMD Radeon RX 570 8GB
MSI B350 PC Mate
Corsair Spec-01
Corsair Vengeance LPX 16GB 2400mhz
Kingston A400 120GB
Seagate Barracuda 2TB
Thermaltake Smart RGB Series 600W
Be Quite! Pure Wings 2
"I don't make mistakes. I make prophecies which immediately turn out to be wrong." ~ Murray Walker RIP
https://linustechtips.com/topic/931828-aio-water-cooling/#findComment-11388533
True AIO are sealed and most never need any maintenance but they also don't last as long and are not a robust I would use something like EKWB EK Fluid Gaming A240 before I would use a AIO in any of my systems with that one you can do maintenance and add on as you grow
https://linustechtips.com/topic/931828-aio-water-cooling/#findComment-11388572
