My PC was running kind of loud lately, so I decided to clean it. I didn't have compressed air at my disposal, so I used a straw and blew into it instead. I removed and cleaned the GPU, I removed the RAM but didn't really do anything with it, I removed the CPU radiator and cleaned it (it was really dusty), and I removed the CPU, got rid of the old thermal paste (on the cooler as well), then applied some new paste and put everything back in. Much to my displeasure, the PC started beeping furiously and continuously for about 15 seconds (I counted around 30 beeps), then turned itself off, only to turn itself back on after a few seconds and restart the process. I turned it off and unplugged everything again, removed the GPU, CPU and RAM, investigated for any issues with the processor (there was a small smudge covering 4-5 plates that connect to the pins. Not sure if it's been there before and I'm not sure what's it made of) and put everything back in, this time with just a single RAM stick, but the darn thing is still beeping at me. What do you suggest I do?
CPU: Core i5 4460
Motherboard: Gigabyte GA-H81-D3
GPU: NVidia GTX 1050 Ti
RAM: Kingston HyperX Fury 2x4GB DDR3
PSU: Corsair VS450
https://linustechtips.com/topic/930725-continuous-beeping-fail-to-post/
CPU: Core i5 4460
PSU: Corsair VS450
https://www.gigabyte.com/Support/FAQ/816
Here is a list of beep codes for Gigabyte boards, see which one lines up to the one you're experiencing.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I've already looked at that before and nothing lines up. Like I said, there were close to 30 beeps, whereas that list only goes up to 11
The beeps repeat. So you have to match the pattern of long and short beeps.
There is no pattern, though. There are just steady, continuous short beeps that last for as long as the PC is working with no discernable pattern
I used the site BlueChinchillaEatingDorito linked. Even though the Gigabyte website suggests my motherboard has an AMI BIOS, the AWARD BIOS had "continuous beeps" listed, so I decided to go with that and assumed it was my RAM.
I have two sticks of RAM and two memory slots.
RAM #1 in Slot 1 - Works
RAM #2 in Slot 1 - Doesn't work
RAM #1 in Slot 1 AND RAM #2 in Slot 2 - Doesn't work
RAM #1 in Slot 2 - Works
Conclusion: Both slots are fine, but one of my memory sticks seems to be broken.
