34 minutes ago, miku126 said:
 titan x maxwell fan ate its own power phases pads, i replaced them with new 1mm pads and it still ate them, can it be fixed or would you recomend getting a new gpu?
semtimus is right on this. a new fan cost $20usd max. a new video card $400+ so don't waste $$$$$$
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
https://linustechtips.com/topic/928661-titan-x-problem/#findComment-11358729
15 hours ago, miku126 said:
if i change the fan, will it suck up the thermal pads?
bear in mind that the thermal pads were pull from under the aluminum shroud covering the PCB
I would replace the thermal pads with new ones when you put the new cooler on (if you decide to go that far), or when you replace the fans. It's likely an issue with the way the fans are pulling the air because of some weird alignment issue, or they just weren't designed well.
https://linustechtips.com/topic/928661-titan-x-problem/#findComment-11361607
