Hello everyone,
I have difficulties enabling Freesync in my Radeon Settings. My Graphics Card is Asus Rog Strix RX580 8GB and my monitor is Viewsonic XG2401(both support Freesync). In my Radeon Settings I can't activate Freesync.
Radeon Settings says that my drivers are up to date and I've installed Viewsonic XG2401 drivers. When I try to install Standard Monitor Driver Signed for Windows 10 x64 it says I should install the unsigned version so I have tried with both
Standard Monitor Driver Unsigned
Operating System: Windows
as
Operating System: Windows x64
I do everytime reboot of PC and I've tried switching Display Ports on the Monitor and on the Graphics Card. Display Port 1.2 is activated under System Setup on the Monitor.
Can you guys please help me?
Thank you.
https://linustechtips.com/topic/927271-freesync-not-supported/
Looks like you need to turn it on via the monitor settings.
Non FreeSync related: Change the Hz via your display adapter properties to 144. I wipe my computer and always forget to the change it back. My computer will default to 59hz if not changed.
https://linustechtips.com/topic/927271-freesync-not-supported/#findComment-11346032
