Hi All,
Looking for some help deciding what chassis to buy for my build that has ongoing upgrades. I live in South Africa, so the selection is very limited when considering price (hoping to keep the chassis cost under $200). These are the brands I am able to get, sourced direct from local distributors:
  • Bitfenix
  • Corsair
  • Coolermaster
  • InWin
  • LianLi
  • NZXT
  • Thermaltake
I'm looking for a case with the following requirements/ preferences but I am battling to find a case that meets all the requirements:
  • Full Tower
  • 3.5" bays (minimum 6)
  • Full ATX support
  • Preferably brushed aluminium / steel design
  • Preferably tempered glass (acrylic scratches way too easily for my liking)
I have considered the following chassis but am concerned for various reasons about getting them, if anyone can take a look and see if my concerns are valid:
  • Thermaltake X71 TG (only 5 x 3.5" bays)
  • Coolermaster Storm Stryker (Acrylic Side, apparently the acrylic side is positioned badly)
  • Coolermaster Casemaster 5 Pro (not full tower)
  • Bitfenix Shogun Window (not full tower, apparently bad cable management, no 5.25" bays, over budget)
  • Corsair 780T (Acrylic Side, Over budget)
  • Thermaltake View 71 TG  (no 5.25" bays)
  • Coolermaster MasterBox 5T (not full tower, no 5.25" bays)
  • Coolermaster Cosmos SE (Acrylic side, over budget)
If anyone can help me out? I'm looking for something that will last years for my build as I've always cheaped out on my chassis and I've finally decided to get something decent as a gaming chassis, because of all my 3.5" HDDs I am concerned about a design that accommodates the necessary cable management.
https://linustechtips.com/topic/926498-chassis-purchasing-advice-needed/
1 hour ago, ETBMikenel said:
Hi All,
  • Bitfenix
  • Corsair
  • Coolermaster
  • InWin
  • LianLi
  • NZXT
  • Thermaltake
  • Full Tower
  • Full ATX support
https://pcpartpicker.com/products/case/#xcx=0&m=169,50,11,58,62,94,56&s=1&J=6,20&t=4&X=0,20829&f=2&G=1,12&qq=1
Has all the stuff you need. Just look for the tempered glass. Filters I put
  • 6 3.5 minimum
  • 1 5.25 minimum
  • Atx full tower
  • Atx mobo
  • And the brands you said
  • Also under $208 USD (none were higher than $200)
CPU i7-7700k 5.5GHz Delidded GPU MSI 1060 6GB ARMOR OCV1 +335/+1000 RAM 16GB 2x8 Corsair Vengeance WLED 2400/3000 C14 COOLER Corsair H100i v1 BOARD MSI Z270 SLI SSD Samsung 960 Evo 250G, x3 2T Samsung 860 Evo HDD WDB 4T, WDB 1T PSU EVGA 650GQ80+M CASE Cougar PanzerS
CPU i7-10700k GPU MSI RTX 2080 Duke POS RAM 32GB 2x16 Corsair Dominator Platinum RGB 3200/3600 CL14 COOLER CM MasterLiquid ML360R RGB Push/Pull BOARD MSI MEG Z490 Ace SSD 980 Pro 500G, 860 Evo 1T PSU EVGA 1000P2 CASE Phanteks Enthoo Luxe TG Black
CPU Pentium G4600 GPU MSI GTX 1080 Armor OCV1 +100/+400 RAM 8GB 2x4 G.SKILL Aegis 2133/3000 CL16 COOLER Corsair H100i v1 BOARD MSI H110M Pro-VD-Plus SSD 860 Evo 1T HDD WDB 500G, WDB 1T PSU EVGA 430W Bronze CASE Deepcool Tesseract/ VIVO
SERVERS i5-3470, i5-3470, i5-4590 GPUS MSI 750Ti 4GB, BFG GTS 250 1GB, GTX 690 RAMS 3x 16GB 2x8 1866 C8 PSUS 2x EVGA 1000T2 COOLERS Stock, Stock, Custom Loop BOARDS Intel, Intel, EVGA Classified SSD x3 860 250G HDDS I don't care to list CASES Optiplex, Optiplex, 2000s Water Case
560HP/607TQ E85 198MPH2000 Audi S4 2.7Bi-Turbo with K04/RS6 Inlets SRM -  DAZ Tune - 2.8L N/A DOHC Heads  -APB Block - Mahle Pistions - JHM Racing H-beam Rods - TheTuner Manifolds - 3.5in to 3in Exhaust with Magnaflow Dual Box - Dual Titanium Exhaust Tips - SAI CNC Delete - S4 Modified Airbox - 85MM Maf- RS4 Intake Manifold p&p RS4 Y-pipe - RS4 Bi-pipes - RS4 Fuel Rail - A8 TTB - Billet Divertervalves - Silicone Hose Everything - SRMv4 Intercoolers - Clutch Fan Delete/Block off - Power Steering Light Pully - FluidAmper - Billet Cam gears - V8 Cam Bolts - ABS Relocate - VW Diesel Oil Pump
I worry about the longevity on the cases that use a lot of ABS on the aesthetics. A friend of mine had a Corsair 600T and after about 5 years the plastics have gone brittle and the clips have started breaking.
As far as I know the 600T is a mid tower, but I'd still be happy with a case around that size. So mid tower suggestions are welcomed if they are big enough.
Can anyone vouch for the quality of these cases after a couple of years based off their experience?
Cougar Panzer Max
