Hello guys,
I have recently moved from my good old sandy i5 to a new Ryzen R7 2700 system. Everything was running just fine up until Wednesday the 9th. After connecting remotely to a SIT server of a project i am currently working on, i was not able to use any browser At all. At that time i just left the problem alone, since i  wanted to rest. Yesterday I resumed troubleshooting my issue. Firstly i tried reducing my OC to stock values. Nothing changed, Then to safe values (DDR4 to 2400 etc) Again nothing changed. Afterwards i proceeded formatting my SSD (windows 7 +Raid Drivers+ injecting ryzen usb drivers via DISM to the install image). After the completion of the installation i proceeded installing firefox... and boom. Same problem arised. I then tried to install the chipset drivers, that one also crashed. Same goes for the GPU driver. I then helplessly tried to install both windows 10 and 7 to another SSD i had laying around, but the problem persists.
This is really frustrating and i need my PC mostly for work. Any ideas? I am suspecting that maybe the mobo is failing (could be the gpu, but there were no signs of it dying -- also got a new one 2 months ago from RMA) or the pSU / CPU.
 All of the parts are pretty new ( about 2 months ago purchased).
Specs:
Ryzen R7 2700 stock
G Skill 16GB FlareX 3200Mhz Cl14
Asus Crosshair 6 Hero
2x 3TB Raid1 Arrays WD Red
1 Samsung 850 Evo 500Gb
2x 1TB wd blue
Corsair RMx 850w White
Bios Version Latest stable (6004)
RX 580 XFX  GTX-XXX 8GB
CPU and GPU in a custom loop with 2 rads ( 1x140 and 2x140)
System tested both w7 and w10 64bit.
The site has changed....
https://linustechtips.com/topic/926250-new-ryzen-build-problem/
3 minutes ago, jimakos234 said:
Hello guys,
Try reseating the CPU, the mounting mechanism isn't great - when I first built my rig I thought I had a dead ram stick/channel, reseated the CPU and it's been fine ever since
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/926250-new-ryzen-build-problem/#findComment-11335739
Have you run any kind of diagnostic tools such as memtest?
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/926250-new-ryzen-build-problem/#findComment-11335787
Just did as told, made no  difference whatsoever :(
No, i have not. Should i use live usb tools, or should i do inside the -faulty- windows?
https://linustechtips.com/topic/926250-new-ryzen-build-problem/#findComment-11335852
USB would give a more correct reading.
Unraid Server
https://linustechtips.com/topic/926250-new-ryzen-build-problem/#findComment-11336026
Hello again. I was able to find RAM from a co-worker  and a gpu. I just retested  and the problem persists. Also,  I have to mention that after Sunday i was not able to even boot in the windows installation, let alone a linux one (since i was getting segmentation faults while booting into linux. I tried Ubuntu,Kubuntu and Arch, all ended up with the same Segmentation fault error).
https://linustechtips.com/topic/926250-new-ryzen-build-problem/#findComment-11349361
