Do you have rubbing alcohol in the pharmacy?  Just get the highest percentage solution you can and use that.  Make sure it's dry before you do anything else after your cleaning.  Rubbing/sterilizing alcohol is isopropyl alcohol with distilled water.
The LTT video above also offers some good alternatives.
