Hey guys, i'm getting a new PC for my friend and was wondering if this is the way to go
I was looking at buying this
http://www.microcenter.com/product/503343/Elite_8300_Desktop_Computer_Off_Lease_Refurbished
and
http://www.microcenter.com/product/472012/GeForce_GTX_1050_Overclocked_2GB_GDDR5_Video_Card
This should be around $400 plus tax and also
or we might buy a desktop for around $350 with a Ryzen 2200g without a graphics card.
What are your guys thoughts?
https://linustechtips.com/topic/923586-refurbished-pc-build/
Get the Ryzen 2200g, it's iGPU should do fine for a while, and the AM4 socket has a better upgrade path than the i5-3470 (Outdated socket). And it's cheaper and more customisable than that refurbed OEM.
DAEDALUS (2018 Refit) - Processor: AMD Ryzen 5 - 1600 @ 3.7Ghz // Cooler: Cooler Master Hyper 212 LED Turbo Black Edition // Motherboard: Asus RoG Strix B350-F Gaming // Graphics Card: Gigabyte GTX 1060 Windforce 6GB GDDR5 // Memory: 2 x 8GB DDR4 Corsair LPX Vengeance 3000Mhz // Storage: WD Green - 250GB M.2 SATA SSD (Boot Drive and Programs), SanDisk Ultra II 120GB (GTA V), WD Elements 1TB External Drive (Steam Library) // Power Supply: Cooler Master Silent Pro 700W // Case: BeQuiet Silentbase 600 with SilentWings Mk.2 Internal Fans // Peripherals: VicTop Mechanical Gaming Keyboard & VicTsing 7200 DPI Wired Gaming Mouse
PROMETHEUS (2018 Refit) - Processor: Intel Core i5-3470 @ 3.2Ghz // Cooler: Cooler Master 212 EVO // Motherboard: Foxconn 2ABF // Graphics Card: ATI Radeon HD 5450 (For Diagnostic Testing Only) // Memory: 2 x 4GB DDR3 Mushkin Memory // Storage: 10TB of Various Storage Drives // Power Supply: Corsair 600W // Case: Bitfenix Nova Midi Tower - Black
SpeedTest Results - Having Trouble Finding a Decent PSU? - Check the PSU Tier List!
https://linustechtips.com/topic/923586-refurbished-pc-build/#findComment-11310094
Depends if your friend wants to upgrade latter down the line. The ryzen platform will give better upgradeability options. The refurb + the 1050 is o k but will eventually become outdated again with no upgradability. Personally id go with the ryzen 2200g as on medium to low settings all games will be more then playable.
https://linustechtips.com/topic/923586-refurbished-pc-build/#findComment-11310096
