I decided to upgrade my desktop to the x299 platform. Got the 7820X, Asus x299-A Mobo, G.Skill Trident RGB 3200 (4 x 8gb) and kraken x62 AIO Cooler
I wanted to use sleeved cables from cablemod so i made sure the ones I purchased was compatible with my PSU (EVGA SuperNova G2 750W)
I made sure everything was plugged in, Double checked the 24pin and the 8 pin ATX power and the other 4 pin ATX power towards the top. When I switch the power on for the PSU, only the lights for the Mobo comes on, no light from the ram or the cooler. Two indicator LEDs also comes on for the GPU.  Pressing the power button on either the case or the mobo makes a tick sound from the psu but nothing else happens. No Post on the mobo either. This is probably still a power issue with some of my cabling. Any help would be appreciated.
Edit- No fans spin either
CPU: i9-13900K |  MOBO: Asus ROG Strix Z790-E | Cooling: Corsair iCUE H150i Elite 360mm AIO | RAM: Corsair Dominator RGB 32GB 6200MHz CL36 DDR5 | GPU: Gigabyte RTX 4080 Gaming OC 16GB | Case: Corsair 5000D Airflow| PSU: Seasonic Prime GX-1300 Gold 1300W | Keyboard: Corsair K95 Platinum | Mouse: Logitech G Pro X Superlight 2 DEX w/ Powerplay
https://linustechtips.com/topic/919905-pc-doesnt-boot-no-power/
https://linustechtips.com/topic/919905-pc-doesnt-boot-no-power/#findComment-11274524
Okay so I tried using my old psu cables again, it came up with a post 53. Then I removed all but 1 stick of RAM but showed 68, tried a different dimm slot then it showed post 66
https://linustechtips.com/topic/919905-pc-doesnt-boot-no-power/#findComment-11274541
