SD CARD not being regognized
Go to solution Solved by ocloo,
every thing is ok, i tried on my friend pc and for some reason, the sd card showed up on his computer.
Hi
I'm using a Sandisk 64GB extreme sd card for more than 2years now, when i decided to use it for the last time. After i filmed every thing, when i went home to get the files on my hard drives, suddenly my mac book pro didn't recognize it, i then insert it via a card reader to my pc and that also didn't help. I have tried other pc's and laptops but nothing help, it will always not show up. does anyone know what is wrong with the card? i really need the files on it.
Greets
Ocloo
https://linustechtips.com/topic/917618-sd-card-not-being-regognized/
One of the possibilities: physical issue. if this drive is not showing in Windows Disk Management, i think you may need to throw it away.
If windows disk management can detect this drive, you can scan this drive with some third party data recovery software such as minitool program. Good luck!
