I'm still planing a water cooled build and im still stuck on reservoir choices. I keep seeing pcs with a D5 pump?
What is a D5 pump and how do you attach it to a reservoir. I really don't want to have a standalone pump but i don't understand how the D5 attaches to a reservoir.
Also do you have to use the D5 with specific reservoirs or can i put it with an EK RES X3?
https://linustechtips.com/topic/915291-how-does-the-d5-pump-work/
https://www.ekwb.com/shop/EK-IM/EK-IM-3830046992987.pdf
The manual probably gives the best picture of how it coupled togeather.
You can use the D5 with any reservoirs. There's obviously comes a few requirements. Like it has to be made for a D5 if it's a all in one unit (pump top and reservoir in one) or if it's a seperated pump top and reservoir only the pump top needs to be made for the D5. If they're seperate, it's just a matter of a couple of fittings and a piece of tubing.
Technically the pump is always something separtae, but you can buy pump-reservoir combos. For example: https://www.ekwb.com/shop/ek-xres-140-revo-d5-pwm-incl-pump
Otherwise you'll need something like a pump top and fittings.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
