Ok so what I usually do for editing is I record my webcam, obs with my game, and vocals all seperetly. This time though I forgot to mute my mic after I did the stuff to sync is on my OBS so now I have webcam, vocals and a video with both vocals and game sound but the game sound is way too loud for the vocals to be heard properly and for people to enjoy it properly. Now if I try to edit them together I end up with an echo since I both have vocals in my gameplay and my audio track so I could mute the in game sound which wouldn't be good because this is a horror game with in game horror elements and stuff and voice actting, or I could mute my main vocals and have unbarably loud in game sounds or I can put in both and have an echo, or preferably there's some way you guys know to fix this? I need to edit it tonight or tomarrow so if you could help with my problem it'd be a great help. and if you don't know what to do to fix it then which of the options I said would you rather listen to? THANKS EVERYONE!!
https://linustechtips.com/topic/913128-need-some-editing-help/
Just now, SpiralTTGL said:
keep vocals and audio prob add subtitles for the video my 2 cents
Well then I could keep in game audio and both vocals and just have an echo or I chould just have vocals and the spliced audio and get really loud in game everything including the already loud music
https://linustechtips.com/topic/913128-need-some-editing-help/#findComment-11209415
honestly if a video has an echo I wouldn't watch
https://linustechtips.com/topic/913128-need-some-editing-help/#findComment-11209419
