I am building a new pc and i needed some help to know if my parts are compatable, any help would be appreciated
These are the parts
MSI GeForce GTX 1060 DirectX 12 GTX 1060 3GT OC 3GB 192-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready ATX Video Card
| Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound AS5-3.5G
| Kingston A400 2.5" 120GB SATA III TLC Internal Solid State Drive (SSD) SA400S37/120G
| Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
| Intel Core i5-8400 Coffee Lake 6-Core 2.8 GHz (4.0 GHz Turbo) LGA 1151 (300 Series) 65W BX80684I58400 Desktop Processor Intel UHD Graphics 630
| MSI Z370-A PRO LGA 1151 (300 Series) Intel Z370 SATA 6Gb/s USB 3.1 ATX Intel Motherboard
| G.SKILL Aegis 8GB 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Intel Z170 Platform Memory (Desktop Memory) Model F4-3000C16S-8GISB
| EVGA 600 B1 100-B1-0600-KR 80+ BRONZE 600W Includes FREE Power On Self Tester Power Supply
| MasterBox Lite 5 RGB ATX Mid-Tower with 3 x 120mm RGB Fans, Tempered Glass Side Panel, DarkMirror Front Panel & 2 Additional Color Trims for External Customization Options by Cooler Master
Thanks alot :)
https://linustechtips.com/topic/911487-building-new-pc-need-help/
These are the parts
Thanks alot :)
According to PC part picker you should be ok. I am assuming you have an HDD to go along with that SSD
AMD Ryzen 3950x under a Noctua D15S, 32 Gb G Skill FlareX 3200 DDR4 running at 3200 CL14, Gigabyte Aorus Pro 570 Wifi, Gigabyte 2070 Super hooked to a Dell U2718Q 4k HDR monitor & an Acer 1440p 144hz IPS panel of some kind, an Inland 1 TB M.2 PCIE 4 main drive, a Samsung NVME M.2 250Gb, WD Blue 500Gb  and 1 TB SSDs, Corsair RMX750, Rainbows and butterflies...
Use pcpartpicker, it makes it easier.
Dont get a 212, youre using a lock CPU which comes with a stock cooler.
I don't know about that psu, but just get a cxm 450W.
You don't need to buy thermal compound, it comes pre-applied
That GPU is going to cost you around ~$100 more than its worth. Either go used (980-980ti) or get a 1060 3gb
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
Unless you're planning to upgrade for a K CPU later you should get a B360 motherboard which will come cheaper than Z370 boards
The Artic Silver 5 is not that great anymore, there are better offererings now such as the MX-4, Kryonaut and NT-H1
The 600W PSU is a tad overkill 500W is more than enough for your build
Other than that it's fine
1. Kingston A400 is one of the slowest SSDs of its type. I'd pay a few dollars more for something like an Adata SU800/SP600/SP550, or Sandisk's SSD Plus.
2. This cooler isnt all that better than your stock cooler, and it's not like the stock cooler wont handle the 8400's heat output quietly anyway.
3. The 600 B1, or simply 600B, is an outdated group regulated unit and not a reliable one. EVGA is known for long warranties, but this one only has 3 years while good units from most brands have 5 or more.
Getting something tier 3 or above from the list. Also, 500W is enough.
Desktop benching:
How much do all these parts cost you in USD
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
Hard to say. Depends on where you buy them from. The GPU is going to be the one with a lot of variance from one seller to another. Try PC-part picker to see where the cheapest deals are. I'd try to replace the 3gb GTX 1060 with a 6gb one. The 3gb one is significantly slower (unrelated to memory size).
https://www.eurogamer.net/articles/digitalfoundry-2016-nvidia-geforce-gtx-1060-3gb-vs-6gb-review_13
