Hi, I need some recommendation about wireless mouse and keyboard. What is the budget needed to buy something decent? I mean, i do not need high-end peripherals, but well made one. My requirements:
1. Two extra thumb-buttons.
2. Long battery life.
3. Work properly on various surface.
What I expect from keybord? Long battery life, normal(long) left shift, normal (big) enter.
I wil  appreciate any suggestions.
https://linustechtips.com/topic/911462-wireless-mouse-and-keyboard/
If you don't need anything more than 2500 DPI, I would recommend the G602. You have 6 thumb buttons, it can last (supposedly) up to 1440 hours, battery operated (not sure if this is good or bad) AND you can get it for $40 USD on Logitech's website right now. I'm not sure about the keyboards though.
Edited by RSX7
clarification
