Ok so i finished building my new computer today and after getting msi Afterburner i saw that my card clock and boost clocks are 139mhz and 405mhz, it is a gtx 1080 amp! extreme with its drivers all up to date and all windows 10 updates as well, was working fine before i changed it to this computer, any help is appreciated!
Specs>
Aorus gaming 7 z370
Zotac Gtx 1080 amp! extreme
16 gigs of ram @3600 mhz trident z rgb
intel core i7 8700k
https://linustechtips.com/topic/910717-gpu-lowering-clocks-dramatically-help/
Just now, XxRustyxX said:
not idling, running metro 2033, still same clocks. lower now actually
getting good fps or shit fps?
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
stuck at 70 so i guess good but should be higher no?
no need for higher, turn up settings.
probably capped at 70fps
no need for higher? i have a 165hz monitor lol yes need for higher, also settings are maxed.
oh lol
have vsync on? sometimes that breaks things in games.
temps?
task manager -> gpu usage?
Try a different driver. Try 381.65, it's the most stable nVidia driver for Pascal ever released. Except it doesn't have Pascal Titanium (Ti) support.
Intel Core i7 4790K 4.8GHz | MSI Z97 Gaming 5 | 32GB 2133MHz CL7 DDR3 | nVidia GeForce GTX 1070 with Custom BIOS | Samsung 850 Evo 500GB | 3TB Seagate FireCuda SSHD | 2TB Seagate FireCuda SSHD | Corsair CX750M  | Custom 240mm all-in-one liquid cooler | Broadcom NetXTREME 5709c Dual Gigabit NIC | Cougar MX330 mid-tower chassis | Windows Server 2008 R2 Datacenter
3 minutes ago, themctipers said:
oh lol
temps?
gpu usage 100% temps 51c vsync off
will do.
