So I recently upgraded my graphic card to the Asus ROG GTX 1080Ti OC edition and using the i7 7700k. I want to upgrade to a dual monitor setup. There is a few ways in my mind right now but I don't know which one makes the most sense.
1. Get the Asus PG258Q along with the XG258Q. Those are 1080p 240hz. The PG258Q would be the main gaming monitor since it has G-sync and use the XG for check stream and such. (Reason to use the XG is because it's a bit cheaper and exact same size and model as the PG258Q)
2. Get the Asus PG279Q with the MG279Q. Those are 1440p 144hz. And usage would be the same as above setup.
3. Get the Asus PG258Q as the main gaming monitor and get the MG or PG279Q as monitor for chat and stream.
Also, aesthetics is a big element in term of doing my set up that's why I have those monitor choices.
Thank you for all the help
https://linustechtips.com/topic/909968-need-help-choosing-monitors-for-streaming/
I would do number two because i have a 240 hz monitor, and honestly I can't tell the difference between 144 and 240 hz.
there's no point getting 240 hz
PC SPECS:
Case: TT View 27 Black
Motherboard: ASRock Z370 SLI XTREME ATX
CPU: Intel Core i7-8700k
GPU: GeForce GTX 1080 Mini ITX 8G
RAM: 16GB G.Skill TridentZ RGB 3200MHz DDR4
PSU: Generic 800 Watt
CPU Cooler: Stock Intel Cooler(*oof*)
SSD: 250GB Samsung 850 EVO
_______________
NON PC STUFF:
Monitor: Alienware 25 Freesync(i know i have an nvidia card)
kb: Corsair K65 Luxe with MX Red Switches(and a white backplate mod to enhance the RGB)
Mouse: SteelSeries Rival 700 at 1600 dpi
Audio: Razer Kraken 7.1 V2
OS: Windows 10 Home, duh
RGB: Corsair Lighting Node Pro with corsair light strips
also the 1440p would do really well with the 1080ti
PC SPECS:
_______________
NON PC STUFF:
