Limited space, custom water loop
Go to solution Solved by SeerreuS,
Finished, at idle operates at 21 degrees C for gpus motherboard 25° C and CPU 27 degrees. I tested superposition last night graphics cards hit 58c. Amazing results as long as she holds tight. I have less than half a liter of fluid in my Loop. Using 120 mm radiator with push pull for two gpus. May not work for all graphics cards but it does for the Asus Rog 1080ti Poseidon.
Front bottom seems like a good spot to me?
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
Yeah that would be the perfect spot. I need to find an alternative for those huge pcie cable. Do they make more custom streamlined cable that are not as bulky as those, it's hard to move them around and right now they're in the way.
1 hour ago, Pangea2017 said:
EVGA power link could bring the cable far enough back with the Reservoir in front of the cable.
This would be optimal position, I will search EVGA power link. Thank you. I've mounted it to the top of case and I'm worried in case of leaks.
You can try bending them such that they run over the top of the cards instead of the bottom. That's how I have my cables.
With that motherboard they make you run the cards so tight together. If I would have noticed that before I bought it I would have got a board with three times 16 slots that way I could have ran it 4 slot SLI Bridge. The top card tables could definitely be routed above the card but the bottom one wouldn't be able to because it would hit fans on top card even though they probably won't be running any more.
Run the cables for both cards over the top of the first card I meant, not each over its own top.
Not that I care about Aesthetics about functionality but I love the Infiniti windows on those gpus I don't want to block them. I went and picked up some rotary 90-degree elbows that should help me out a lot and getting one of those pci-e cables over the top of the upper card will help out a lot also. And the EVGA powerlink will not work on my card.
I'm going to mount Reservoir at the top coming from the left side of the case. That will allow me to use the fill cap removing the top of the case with potential of spilling fluid down on all the components below at the same time though nervous. I'm starting in a couple of hours I think that's my best solution I've been researching for 2 days.
Slow going. I melted rubber insert inside petg first time. 300*f is perfect temp. I beveled edges of petg tube and I still shaved a little bit of the o ring from the fitting when inserting tube. Will this cause a leak, or is a little shaving ok?.
Edited by SeerreuS
I've been running a leak test for an hour 45 minutes now and it's a good thing because I found the leak and you'll never guess where. I checked and double-checked and triple checked every connection on every fitting on every hose except one. The temperature sensor the top cap wasn't tight, and I thought it was just like a rotary I was wrong.
