CS:GO Low FPS
By
Guest DeWat4
in Troubleshooting
in Troubleshooting
Solved by Guest DeWat4,
12 minutes ago, JaegerB said:Try display driver uninstall, its a software to uninstall your graphics drivers so you can reinstall them. Also, check your processor is running at full speed with HWMonitor, if you don't have it already.
FIXED IT! I had to set my NVIDIA GPU to the global default. Thanks for doing your best to help though!
_Darasuum_ ·
Posted in Power Supplies4 -
1
4
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting4 -
Ozzi ·
Posted in Networking5 -
3
play_circle_filled
Latest From ShortCircuit:
