Hello, So
Ive made a post about this already,
 I thought id try to go more into detail.
So I build my PC about 2 years ago, It has been fine for this past year an a half, And now out of no where my whole PC well crash.
There is NO error messages when it crashes, The whole computer Freezes, everything on the screen Freezes, (Still shows what i was last on). And i have to hit the restart button to restart my computer.
This happens about 2/3 times a Day.
**note** IT does not crash When im under Load, IT happens when ever, Watching youtube videos, Games, Microsoft word...etc.
Ive been told It could be a bad Windows install, ( I never re downloaded windows, Never tried)
Ive been told it could be a bad program install, SO i reset my PC to factory settings, Still freezes.
I really have no clue what the problem is.
Here Is a Gyazo GIF of my CPUID HWMonitor (Made it a gif bc things change)
**This is Right after it crashed**
https://gyazo.com/160f75c290870758ec01414d85145b96
If needed Ill show more.
PC build vvv
https://linustechtips.com/topic/907161-computer-crashing-help/
Have you tried disabling AMD TurboBoost in the BIOS?
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11150906
Hey!
So, im not completely computer savvy when it comes with the whole BIOS thing, So ive been hesitant to touch any of that stuff,   You think that could be the problem?
Is there any Guides that show you how to do that kind of stuff? Dont wanna mess anything up.
EDIT: Ive seen alot of posts saying keep it on IF you're not overclocking... Im not overclocking.
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11150913
Just now, johnukguy said:
Have you cleaned the PC out, checked all your cable connections, done a disk check, run system file checker and run decent (in other words not Windows Defender, McAfee or Norton) anti virus/anti malware scans?
Hey!
Thanks for the reply!
Yes I have crazy OCD so i clean my PC in and out once every 2 months,
When it comes to cable connections, I have 3 things running in a Power bar, thing, My Screen, PC and a speaker, Dont think that would be the problem?
File Checker Im running right now! Well reply when its done,
And for Virus checkers, I did have Norton (paid)
Thanks!
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11150980
1 hour ago, Foul said:
Hey!
I was just going off a friendly Google search of your CPU :P
What kind of RAM do you have (DDR3/4) and how is it arranged?
What kind of Storage do you have (HDD/SDD/M.2/PCIe)
Specifically, what is your motherboard model?
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11150989
Just now, DaJakerBoss said:
I'm just going off a friendly Google search of your CPU :P
I thank you for the help!
DDR3 8gigs 4 and 4 But i forget the arrangemeant
3TB HD
MSI 970
Sadly I think it is the CPU!
Ive seen 2 other posts on here with the FX 8350 That Freezes Randomly :/
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11151009
MSI 970
could you be more pacific?
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11151021
Okay here's a general guess as to how to disable it:
You're going to need to find your way into the BIOS (appears to be holding DEL as the computer boots)
Next there's a option that reads "AMD Turbo Core Technology" in the Overclocking (OC) category:
image.png.2319f75c03cb8327f12059fc26ac17c5.pngMy assumption here is that if you turn this option from Auto to Off, you will have disabled it and you can try rebooting into Windows.
The hopeful solution is from a TomsHardware post where someone fixed the freezing by disabling this.
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11151072
Thanks a ton for the help!
And I do see that guy has almost the same problem as me !
Ill do some more googling and check it out
Thanks Alot!!!
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11151101
Thanks Alot!!!
Yup! Please do come back if this doesn't work!
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11151108
On 3/19/2018 at 8:36 AM, Foul said:
Hey, So ive turned it off, And Just turn my computer on to do some homework, within 20mins of it being on in Froze again :/
oh boy. I will do some more checking. You wanna take some pics of your bios if you can?
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11157729
LOL
I have Ordered a Ryzen 1600x no need for anymore checking, This shits getting set on fire.
jkjkjkjkjk But still Fuck FX series, Thanks for the help!
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11157734
17 minutes ago, Foul said:
LOL
  Reveal hidden contents
LOL GOOD CHOICE
YOU DID YOURSELF A FAVOR MAN
https://linustechtips.com/topic/907161-computer-crashing-help/#findComment-11157785
