Hello Guys, Can anyone suggest me a custom build PC with a good processor and enough of RAM? And by the way it would be nice if it would be under budget!
I do work like pen-testing, (a lot of ) internet surfing, and a little gaming like DOTA 2 and Splinter Cell, etc
Thanks in advance!!
https://linustechtips.com/topic/907093-custom-build-pc/
So whats the budget?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/907093-custom-build-pc/#findComment-11150334
Just now, TheTechGuy369 said:
Actually there's no budget at all but it would be nice if it would cost a little low.
gonna need a range or a set budget, which country? need os/monitor/peripherals?
https://linustechtips.com/topic/907093-custom-build-pc/#findComment-11150345
Just assume that I have no budget just need a medium - end - PC thats all; India; no need for os,monitor, peripherals , etc
I just need the CPU cabinet and all the stuff inside it like CPU ram motherboard hard disk, etc etc.
And also PSU and all other required stuff!!
https://linustechtips.com/topic/907093-custom-build-pc/#findComment-11150356
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (₹16858.00 @ Amazon India)
Motherboard: Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard  (₹8949.00 @ Amazon India)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3000 Memory  (₹14112.95 @ Amazon India)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  (₹6249.00 @ Amazon India)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (₹3198.00 @ Amazon India)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Strix OC Video Card  (₹34499.00 @ Amazon India)
Case: NZXT - S340 Elite (Black/Red) ATX Mid Tower Case  (₹9045.00 @ Amazon India)
Power Supply: EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (₹16307.00 @ Amazon India)
Total: ₹109217.95
Generated by PCPartPicker 2018-03-18 22:50 IST+0530
I have no idea if that suits your budget, however this is what I would class as a mid level build - The faster ram is required by Ryzen for decent gaming performance and an SSD for loading times.
1 hour ago, TheTechGuy369 said:
Thank you FrostieCookie I appreciate it
But, can you suggest me a build half that cost
It's in my budget but I want it as low as possible.
guess that rules out mine, this is the problem when you say there is no budget
Total: ₹109217.95
Ryzen Ram Guide
https://linustechtips.com/topic/907093-custom-build-pc/#findComment-11150431
https://in.pcpartpicker.com/list/F8gyfH
Same rule apply. Keep in mind that this build is less powerful.
https://linustechtips.com/topic/907093-custom-build-pc/#findComment-11150450
