Need help!
My desktop wont turn on. No power, no lights, no nothing. No response from the power button.
I played before going to sleep it was still ok that time. I left it open so i can download a 27gb dlc (my internet's slow so i tried to download it overnight). When i woke up the PC was off, i tried to turn it back on but it wont turn on.
Any comments and suggestions is much appreciated.
Also i just recently upgraded my pc.
Here's the specs:
Processor : amd A8 -> ryzen 5 1600
Mobo: gigabyte F2a58m-ds2 -> msi bazooka b350
Gpu: msi radeon rx580
Ram: hyperx fury 8gb 1866 -> hyperx fury 8gb 2400
Hdd: 1tb wd & 2tb wd
PSU: Thermaltake smart se 630w
Case: orion atx -> phanteks eclipse P300
https://linustechtips.com/topic/907022-help-pc-wont-power-up/
See, the "it turned off overnight while I slept" is always a tricky problem, but I'll try and help.
I'd start with clearing CMOS. I'd also suspect the PSU from the start, because who knows, maybe there was a power surge overnight.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/907022-help-pc-wont-power-up/#findComment-11149792
Thanks. I'll update once i get it done.
https://linustechtips.com/topic/907022-help-pc-wont-power-up/#findComment-11149799
5 minutes ago, Pustulio said:
I removed and reseated the CMOS on the motherboard. Still no power. Maybe it's the power supply, though i cant be sure cause i have no spare lying around.
Go to a store nearby (if you have one) and just buy something cheap that you can return later (by cheap I mean of good quality, just a low price).
EDIT: Does the PSU smell like ozone?
SPECS:
https://linustechtips.com/topic/907022-help-pc-wont-power-up/#findComment-11149823
It's late in my country so i can't buy a replacement now. Maybe tomorrow.
I don't think so. Smelled it earlier, no sign of burnt circuitry. Also i tried shorting the power switch but still no response.
https://linustechtips.com/topic/907022-help-pc-wont-power-up/#findComment-11149834
