Hello guys,
I couldn't find concrete info on this so im starting a new topic, if I have overlooked an already existing thread on this, please send me a link.
Anyway, I was overclocking my 6800k to get a final highscore in cinebench r15 before i diled in a more conservative oc for the first time and noticed that the vcore I entered in the bios (1.365v for 4.445 ghz, 1426 score) actually read 1.43 v on the motherboard! (asus strix x99 gaming)
I know that Broadwell-e has an integrate voltage regulator and the imput voltage was fixed to 1.9v and the cache voltage at 1.28 so what voltage did i actually read?
Asus tends to overshoot the voltage a bit and my llc was pretty conservative aswell.....
Now i changed vcore to 1.2v and it still reads 1.38v on the mobo but all software ( from hardware info 64 to cpuz reads 1.2v)
btw, i messured directly on the back of the socket because i dont know any other checkpoint....
Thank you in advance for the answers^^ i really dont want to break anything when i try to place nr1 on firestrike for the 6800k 980ti combo (currently nr3)
https://linustechtips.com/topic/902536-6800k-vcore-issue/
If that mobo voltage is named 'VID' then it doesnt matter.
Desktop benching:
https://linustechtips.com/topic/902536-6800k-vcore-issue/#findComment-11105997
2 minutes ago, holodrio said:
it is not the VID. im not new.
How about showing us sensor data from HWinfo? Maybe some pros can read it
Desktop benching:
https://linustechtips.com/topic/902536-6800k-vcore-issue/#findComment-11106023
could take a screenshot but the vcore is 1.2.... just like i entered.... same as the VCCIN which is 1.9v which also messures 1.9v on the mobo.....  the real question is, can you even messure vcore correctly on cpus with an integrated voltage regulator?
https://linustechtips.com/topic/902536-6800k-vcore-issue/#findComment-11106038
I think you can. I mean, if you cant then that's a big design flaw on Haswell and Broadwell.
Desktop benching:
https://linustechtips.com/topic/902536-6800k-vcore-issue/#findComment-11106047
