I want to build a system in the in win 301 I have already decided on the RGB fans I want to use but they only have a 3 pin fan connection will the work if I plug them into the 4 pin slots?and I need 1 intake fan what would you recommend.it would be the only intake in the system the hardware will be a 2400g and a Vega 56 later after the Mining shitfest IS over
https://linustechtips.com/topic/901527-case-fans/
They will work just fine. Only different between 3 and 4 pin is 4 pin is PWM where as 3 pin will just adjust the voltage.
The 4-pin connectors use their additional connector to change fan speed on the fly through a process called pulse width modulation. The 3-pin connectors are used to control the fan speed through voltage differences.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/901527-case-fans/#findComment-11096237
Yes you can plug a 3pin header into the 4 pin on the mobo, it just leaves one pin standing alone.
For you intake, what size should it be? I would personally go for a BeQuiet! silent wing, even though I dont have any
140mm:https://www.newegg.com/global/de/Product/Product.aspx?Item=9SIA68V46Y1202&cm_re=silent_wing_3-_-9SIA68V46Y1202-_-Product
120mm:https://www.newegg.com/global/de/Product/Product.aspx?Item=9SIA68V46Y1209&cm_re=silent_wing_3-_-9SIA68V46Y1209-_-Product
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/901527-case-fans/#findComment-11096238
120 mm and thank you I will check them out
https://linustechtips.com/topic/901527-case-fans/#findComment-11098397
