Just now, BlitZerWolf2861 said:
I plan to build a PC with either the Ryzen 2200G or the 2400G.
Whats the fastest ram speed or frequency?
The sweet spot price/performance-wise is 3200MHz so I'd look for that.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
2 minutes ago, BlitZerWolf2861 said:
What would be a cheaper option?
3000 and 2666
Desktop benching:
It's up to you, but with APUs, memory speed is very important because integrated graphics use system RAM as their video memory and the faster = the better.
12 minutes ago, Jurrunio said:
3000 and 2666
Okay, I would also like a mobo recommendation, no overclocking is intended.
Oh, you definitely should overclock. Steve from Hardware Unboxed will tell you more:
