I have a pretty normal PC but it has a huge bottleneck in many games, so please say what should i do to fix it. In example in Just Cause 3 on lowest settings possible in 1080p i have 30fps but i have a pretty good PC.Help PLS!
My specs:
Intel Xeon E3-1231 v3 3.4Ghz
Gigabyte GTX 960 2GB Mini
16GB DDR3 RAM
GA-H81M-S2H motherboard
120GB SSD
1TB HDD
https://linustechtips.com/topic/899220-huge-bottleneck-help-pls/
My specs:
16GB DDR3 RAM
120GB SSD
1TB HDD
I would say look at your CPU, as it could be causing a bottleneck. Although don't take my word for it, can anyone else confirm?
Who needs fancy graphics and high resolutions when you can get a 60 FPS frame rate on iGPUs?
I have that CPU paired with a 970 and it runs JC3 pretty maxed out just fine.
OP, check your temps
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
3 minutes ago, shevlfs said:
The other programs running while playing you mean or the % of cpu or gpu loaded while playing?
Like, when you are running a game, what are your usage percentages at for your CPU and GPU.
I have a gtx 970 that is overclocked heavily and I have a i7 6700 (clocked similarly to your cpu). I believe there's no bottleneck and that something else is holding back your system such as background tasks or thermal limits. It may be your gpu's problem because that isn't a strong gpu.
Use this to find out if you have a bottleneck: http://thebottlenecker.com/#calculator
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
28 minutes ago, shevlfs said:
Hey?
Yeah I mean if you're hitting 99% GPU usage that means your GPU is giving it all shes got trying to push those frames out. Don't know what else to tell ya.
