Visual Studio 2017 Calculator Help
Hello, below is an equals button method for a calculator that was made in Visual Studio 2017 that is in C#.
Can anyone help me to append it and get the history.text, put it into a string variable, so that I can add the string to a ListBox to store the history.
        protected void ButtonEquals_Click(object sender, EventArgs e)
            if (calc_result.Value == string.Empty)
            {   // User must enter a value for the button to function correctly.
                Response.Write("<script>alert('No Value is given.')</script>");
            else
                ViewState["Value2"] = calc_result.Value;
                calc_result.Value = string.Empty;
                try
                    if ((string)ViewState["Operation"] == "Addition")
                        calc_result.Value = _Calculate.Add(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    else if ((string)ViewState["Operation"] == "Subtraction")
                        calc_result.Value = _Calculate.Subtract(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    else if ((string)ViewState["Operation"] == "Multiplication")
                        calc_result.Value = _Calculate.Multiply(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    else if ((string)ViewState["Operation"] == "Division")
                        calc_result.Value = _Calculate.Divide(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    else if ((string)ViewState["Operation"] == "Percentage")
                        calc_result.Value = _Calculate.Percentage(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    else Response.Write("<script>alert('No Operation was recorded.')</script>");
                catch (FormatException)
                    Response.Write("<script>alert('Bad Input Format.')</script>");
https://linustechtips.com/topic/899019-visual-studio-2017-calculator-help/
create a variable to hold the history
string = historyText;
create a method and call it after every response (with the responseText being your string alerts):
        void historyTextFormatter(string responseText)
            historyText = historyText + "[" + DateTime.Now.ToString() + "]: " + responseText + Environment.NewLine;
so far this is what I put in
void HistoryTextFormatter(string responseText)
     string HistoryText = null;
     HistoryText = HistoryText = "[" + DateTime.Now.ToString() + "] " + responseText + Environment.NewLine;
I called the method but in the equals button click but it doesn't know what responseText is.
[/code}
If you declare the HistoryText inside the method then it'll get reset every time you use it, you should declare a global variable to store the HistoryText to retain the entirety of it. Declare it below the partial class.
The responseText will be provided by you, it shall contain the alert you wish to input for your history such as "No values is given", "Bad input format".
I'd personally store those inside a switch case along with the HistoryTextFormatter method.
You can do it like this:
        void HistoryTextFormatter(int responseCode)
            string response;
            switch (responseCode)
                case 1:
                    response = "No Value is given.";
                    Response.Write("<script>alert('" + response + "')</script>");
                    historyText = historyText + "[" + DateTime.Now.ToString() + "]: " + response + Environment.NewLine;
                    break;
                case 2:
                    response = _Calculate.Add(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    break;
                case 3:
                    response = _Calculate.Subtract(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    break;
                case 4:
                    response = _Calculate.Multiply(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    break;
                case 5:
                    response = _Calculate.Divide(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    break;
                case 6:
                    response = _Calculate.Percentage(Convert.ToInt32(ViewState["Value1"]), Convert.ToInt32(ViewState["Value2"])).ToString();
                    break;
                case 7:
                    response = "No Operation was recorded.";
                    break;
                case 8:
                    response = "Bad Input Format.";
                    break;
                default:
                    response = "Unknown response, contact an admin immediately";
                    break;
            // Switch Response Codes
            // 1 = No Value is Given
            // 2 = Addition
            // 3 = Subtraction
            // 4 = Multiplication
            // 5 = Division
            // 6 = Percentage
            // 7 = No Operation was recorded
            // 8 = Bad input format
                HistoryTextFormatter(1);
            else
                try
                        HistoryTextFormatter(2);
                        HistoryTextFormatter(3);
                        HistoryTextFormatter(4);
                        HistoryTextFormatter(5);
                        HistoryTextFormatter(6);
                    else
                        HistoryTextFormatter(7);
                    HistoryTextFormatter(8);
How would I then connect the entire equation to the list box in my calculators UI? So that every time the equals button is clicked, it adds to the ListBox that I named LBHistory.
Ultimately everytime I press equals, I would like the list box to look something like this for example:
1 + 1 = 2
2 + 2 = 4
3 + 3 = 6
I forgot you had a listbox, I was under the impression that you simply wished to store the string of responses. If that's the case I'd use a different approach, I would bind the listbox to an observable collection so you can view it on real time (you could get by just by creating an array and appending it to the list box but it's better to store them inside a collection if you wish to easily transfer them to a database, export it as a text file, to use it as a source for a grid or if you want to use some filtering).
1. First you have to create a class that the collection will use as parameters (declare it below the partial class)
a. ResponseDate = contains the raw date for back-end use
b. ResponseText = contains the raw text for back-end use
c. ListBoxText = the formatted representation of ResponseDate and ResponseText for front-end viewing
        class ResponseClass
            public DateTime ResponseDate { get; set; }
            public string ResponseText { get; set; }
            public string ListBoxText { get; set; }
2. Create the Observable Collection (declare it below the partial class)
        ObservableCollection<ResponseClass> ResponseCollection = new ObservableCollection<ResponseClass>();
3. Bind the:
a. Collection to your list box (place this after the InitializeComponent)
b. Choose the ListBoxText from your ResponseClass as the list box's DisplayMemberPath to tell it to show those values as its visual representation for their respective row
            listBox.ItemsSource = ResponseCollection;
            listBox.DisplayMemberPath = "ListBoxText";
Alternatively, you can bind it through XAML
ListBox ItemSource="{Binding ResponseCollection}" DisplayMemberPath="ListBoxText"
4. Populate them via the HistoryTextFormatter method
            string response;
            DateTime dateNow = DateTime.Now;
                case 1:
                    ResponseCollection.Add(new ResponseClass { ResponseDate = dateNow, ResponseText = response, ListBoxText = "[" + dateNow + "]: " + response });
                    break;
                case 2:
                    break;
                case 3:
                    break;
                case 4:
                    break;
                case 5:
                    break;
                case 6:
                    break;
                case 7:
                    break;
                case 8:
                    break;
                default:
                    break;
5. Create the event that will call the HistoryTextFormatter method
            // 2 = Addition
            // 3 = Subtraction
            // 5 = Division
            // 6 = Percentage
            else
                try
                    else
1 + 1 = 2
2 + 2 = 4
3 + 3 = 6
Do you want to only show successful calculations or responses such as bad input format, etc as well?
