I recently got a usb 3.0 hub for my computer to run my rift sensors and headset, as I didn't have too many 3.0 ports beforehand. The only way to power it is using a 6-pin to molex cable, and the cable that came with my PSU has like 3 unnecessary connectors at the end. I tried to look up cables that were just a 6 pin to molex with no others hanging out but all I could find were ketchup and mustard cables. Anyone know where I can find a decent looking 6 pin to molex cable? Thanks.
https://linustechtips.com/topic/898970-decent-molex-cable/
I think you would have better luck with a sata to molex adapter.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/898970-decent-molex-cable/#findComment-11070836
https://cablemod.com/
https://linustechtips.com/topic/898970-decent-molex-cable/#findComment-11070840
Your not going to many results due to the fact each PSU uses a different pinout.
You can have someone make one or you could just build it your self if you have the tools.
Shops that make quality cables:
https://mod-one.com/custom-full-length-power-supply-cables/mdpc-x-sleeved-cables/
https://www.ensourced.net/
https://mainframecustom.com/product-category/full-length-custom-power-supply-cables/evga-power-supply-cables/
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/898970-decent-molex-cable/#findComment-11074709
