I have the Nvidia control panel in the bottom right in info overflow. When I try opening it nothing happens. I have tried clean installs several times, and have used DDU. What should I do?
i5-8600k, MSI Z370-A Pro, 2x 8GB DDR4-3k, MSI Gaming X 1060, NZXT S340, 2TB HDD, 750w Corsair PSU, AOC 2775 OC'd to 80Hz and CFG73 at 144hz
Comic sans is the worst font
Check out my monitor overclocking guide
https://linustechtips.com/topic/898181-nvidia-control-panel-wont-open/
14 hours ago, Ethocreeper said:
can you open it from control panel?
Like the one on windows 10? I can't get into the Nvidia one.
like this one
How do you get to this menu? I thought this hasnt been a thing since win7
13 hours ago, Ethocreeper said:
write control panes in the search thing
I can get to this, how do you get to the all control panel icons. Thanks for the help
press the view by and then large icons
Same thing. I can see it, but nothing happens when I click it
press the view by and then large icons top right of the window
I think that my issue is nvidia display driver service is missing.
