So I watched an old LTT video on overclocking, as I may upgrade to a i5-4790k, and got bored, so I decided to mess around with the bios of my i5-4460... which caused my CPU from being able to scale with whatever task I was doing, e.g reaching 3.4 GHz when gaming etc, but now when I pin it at 100% usage, it only goes to 3.2 GHz, any ideas on what the hell I’ve done?
I didn’t change any major setting and only applied my memory to run at 1600 MHz.
Before my Cinebench score was 465, and now it’s gone down to 444.
https://linustechtips.com/topic/897635-help-with-i5-4460/
It's normal. The CPU only reachs 3.4GHz when 1 core is at load. When all 4 are under load, it will only reach 3.2GHz. Your game probably doesnt use more than 1 core.
As for the score difference in Cinebench, that's within the margin of error (barely, but still)
Desktop benching:
https://linustechtips.com/topic/897635-help-with-i5-4460/#findComment-11056736
Check the independent app usage in Windows Task Manager. If it's 80% in videos, but <10% at idle, then you arent using hardware acceleration and the CPU is decoding the video.
Desktop benching:
https://linustechtips.com/topic/897635-help-with-i5-4460/#findComment-11056814
