Do I Need a Better CPU?
Go to solution Solved by bimmerman,
5 minutes ago, TVG33K said:
Either way, I just realized, I would have to buy 8gb ddr4. That is really hard to come by for a decent price, and that is more time I need to save up. :|
This seems like a good option, I will try to do some research to see what I can get. Would you say that 3ghz should be the least I can take, or does it not matter as much as just getting the quad core upgrade?
Honestly I don't know. Go for the fastest chip you can afford, fastest quad core if you can. Save a bit more if you need to.
Hello!
I just bought (somehow) a brand-new RX 560D (Rebranded 460) during the past few weeks. This is good, and it is definitely better than what I was playing on before, but I have an issue. I, being pretty new with building PCs, thought that my computer was having a hard time because of my graphics card, but I think I was wrong, although the graphics definitely where terrible.
I have been living the past five months gaming with my dads old GTX 460, and a motherboard and stuff I got for an amazing deal. The GTX 460 was freaking slow, and definitely needed an upgrade. The processor I was using came with my motherboard and RAM. I got my motherboard, 8 GB DDR3 RAM, and a Pentium E5300, for only $25.00 USD.
Online, I saw that the RX 560D (RX 460) could game in most games with outstanding performance, and it was perfect for me, so I bought it. The performance is better, but definitely not tip-top, and I think it is the CPU. Dual core, 2.6ghz, it is not so beastly.
The question I am asking here is, would it be better to keep what I have, or with the little bit of money I have (about $20.00) try to get a Core 2 Quad Q6600 @ 2.4ghz? I tried to get a 3ghz Xeon to mod to LGA775, but it did not work. I just need to know my best option, and I am still new at this.
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/
You are going to want to get a different CPU, because it will bottleneck the 560D.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048500
Just now, TVG33K said:
Is the Q6600 a better option, or no?
No, you need a new current-gen processor, maybe a Ryzen 3 1200.
Daily Driver:
Gaming PC:
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048523
the q6600 will be fine as long as you don't plan to play pubg or any other monkey coded game (looking at you ubisoft)
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048537
I would say if you can afford it, you really need to upgrade, Intel isn't really the best option right now imo, coming from a former Intel user for the last 15 years. Ryzen with a good Mobo preferably 370x Chipset or better idk what the current best is but I'm using a Taichi Mobo.
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048543
3 minutes ago, TVG33K said:
Should I be able to play Fortnite or Subnautica on medium/high settings?
yeah fortnight should run pretty good. i have no experience with subnautica so i can't say anything about it.
like all the others say upgrading would be a nice boost for you but sometimes it's also fine to stay with what you have. we're not all rolling in cash
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048569
For a tighter budget, B350 is the way to go. There isn't too much benefit from X370 from what I can tell.
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048600
Given your budget is ~$20.....I'd say either live with what you have (free!) and save for a while for something newer, or if performance is that bad, try the C2Q. I would make sure that the C2Q will fit on your motherboard socket AND that the motherboard chipset will support the CPU. Back in the day sockets were not changed as often as chipsets, so physical compatibility doesn't guarantee electrical compatibility.
As for how to check that, see what CPUs HP supports in that motherboard, and try to buy the best one you can find.
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048616
he linked mobo support page core 2 quad yorkfield is supported
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048625
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048640
https://linustechtips.com/topic/896807-do-i-need-a-better-cpu/#findComment-11048670
