Air Cooler Help.
Go to solution Solved by deXxterlab97,
Temperature wise it is a downgrade. Noise wise it is a bit stepup.
But since you do not do hardcore OC then H7 is plenty.
Hello dudes.
After having loads of issues with AIO's I decided to move to an air cooler. Currently in my system there is a H100i v2 (that Corsair Link does not recognize) but I have just purchased a Cryorig h7
As I have never used an air cooler before I have some questions. First one is.. it is a mistake? Am I downgrading?
Second one, on aesthetics, when using a Air Cooler do you guys still have exhaust fans at the top of the case or do you not bother? Normally for me there would be a radiator there.
Btw I have an i7 8700k (no plans for any crazy overclock) and a Meshify C case.
Thanks.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/896667-air-cooler-help/
SPECS: Intel Core i5-4460 // PowerColor Red Dragon RX 480 4GB // 1x8GB DDR3 RAM // Delta 500AB-6A PSU // HyperX Cloud Stinger / Logitech G710+ / Logitech G502 / Xbox One Halo Guardian controller // LG 24M45H 1080p //
How to cope with depression
Spoiler free review of Life is Strange (Video Game)
https://linustechtips.com/topic/896667-air-cooler-help/#findComment-11046886
Thanks dude.
How about the fans thing? Any sugestions?
https://linustechtips.com/topic/896667-air-cooler-help/#findComment-11046890
When I'm using an aircooler I at least use 1 exhaust fan but for aesthetics I prefer to fill all exhaust slots with silenced optimized fans.
PC Specs: Intel Core i7-8700k - Asus ROG Z370 MAXIMUS X HERO - 2x8gb Kingston Predator DDR4 3200MHz - MSI GeForce GTX 1080 Ti gaming X Be Quiet! Dark Rock Pro 4 - Samsung 850 PRO 256gb - Samsung 850 EVO 500gb - Seagate Barracuda 2tb - Fractal Design Meshify C - Asus PCE-AC56 - Be Quiet! Straight Power 10 CM 700W.
Peripherals: Corsair K70 LUX - Steelseries Rival 310 - Dell S2417DG - Beyerdynamic Custom One Pro - Audioengine D1.
https://linustechtips.com/topic/896667-air-cooler-help/#findComment-11046906
Cool. I think I will probably do that and just having them running low.
https://linustechtips.com/topic/896667-air-cooler-help/#findComment-11046920
I'm doing the same thing. I've bought some Corsair SP120 Quiet fans and have them running at like 30%. I barely hear them at all :) And for looks, it's great!
https://linustechtips.com/topic/896667-air-cooler-help/#findComment-11046924
Yeah I got some LL ones so RGB'ness!
https://linustechtips.com/topic/896667-air-cooler-help/#findComment-11046929
