Hi there forum,
Can someone please explain this for me? (Image attached)
I do a lot of renderings at work/home using the same software and templates. I'm running a i5-4690 @ 3.50GHz in the desktop at work and a i7-6700k 4GHz Laptop at home.. in-fact all specs are improved a few years in the laptop (metabox).
The problem I'm having is that the Laptop takes twice as long to render as the desktop. I opened up the CPU interface and noticed I'm only reaching about 16% utilization while the MHz is almost maxed out. I'm mostly savvy with computers but have never touched CPU settings so don't want to dive in there without any advice first (For all I know it could be a software error).
Any help appreciated.
https://linustechtips.com/topic/896193-cpu-low-usage-high-mhz/
5 minutes ago, ph88 said:
Hi there forum,
usually rendering uses GPU more than CPU I think? It may be a software setting as rendering softwares do have settings to use GPU as well so maybe the laptop is using more GPU. 6700k is a really good chip ...yes it has good overclockability but I don't think that is your issue here. Cpu speed with max out under load that is normal but the 2x time is not unless somthing was getting really hot and it obviously is not. I think very much this is a software setting.
https://linustechtips.com/topic/896193-cpu-low-usage-high-mhz/#findComment-11041929
Quote
Minimal :
System : Windows 7 / 8 32-bit / 64-bit
CPU : Intel Core 2 Duo 2.4 Ghz or better / AMD Athlon X2 2.8 Ghz or better
RAM : 4 GB
GPU : 1 GB VRAM, NVIDIA GeForce GTX 460 or better / ATI Radeon HD 6850 or better
Hard disk drive : 5 GB free space
3 button mouse
Internet connexion for downloads and for licenses with expiration date.
Recommended :
System : Windows 7 / 8 64-bits
CPU : Quad core processor 3.0 Ghz or better
RAM : 8-16 Go
GPU : 4 Go VRAM, NVIDIA GTX 770 or better / ATI Radeon R9 280X or better
3 button mouse.
Do you meet Recommended GPU hardware in your laptop?
site: https://twinmotion.abvent.com/help/TM2016/EN/index.html?hardwarerequirements.html
https://linustechtips.com/topic/896193-cpu-low-usage-high-mhz/#findComment-11043177
Sorry for the late reply, I didn't receive any emails notifications.
Yes you're probably right. I usually render in Maya and other CPU based rendering software. Twinmotion is based on the Unreal Engine which I guess is GPU based due to live rendering.
I'll run some tests on my gpu and see if anything is out of the ordinary.
GPU is a Pascal GTX 1060 (Laptop), should be fine thanks for the specs. The scene is massive, might just be too much.
https://linustechtips.com/topic/896193-cpu-low-usage-high-mhz/#findComment-11064656
which GPU you have at work?.
If its a quadro it would make perfect sense.
https://linustechtips.com/topic/896193-cpu-low-usage-high-mhz/#findComment-11067787
