Hello!
So I'm planning on watercooling my computer. My case is a S340 elite so I don't think I have any other choice but to have 2 rads in the computer.
For the blocks, I'll go with EK: Supremacy EVO Acetal+Nickel (8700k @ 5.0 GHz) and FC GeForce GTX FE Acetal+Nickel for my Titan Xp.
For the radiators (120mm fans), fittings, pump/reservoir combo and coolant (red) I need some help.
I'd like some help to build my a list of compatible components to build the loop.
Thank you!
https://linustechtips.com/topic/893684-need-help-for-the-best-loop/
Honestly i would use a heatkiller pro over any ek block,The heatkiller blocks do cool the best of anything on the market.They also make gpu blocks if you want that.And on the rads if you go thin i would take hardware labs rads over eks thin ones.Thumb around the water cooling part of http://www.performance-pcs.com/
And if you need help they can help you also,They do carry all brands and build a lot of water cooled rigs.
