Need help with Mac screenshots
Solved by Exothermia,
3 minutes ago, ShadowWolf810 said:That is perfect thank you very much!
I just had another thought, I think I'll use both screenshots if you've got time to make one quick addition.
Exact same layout on everything else, but can you do another and put a folder inside of "Control" called "Learning Avid Project" and twirl Control open.
After that I'll be golden! Thanks again
Like this?
