Check for HDD or CPU spikes that can cause the game to stutter or check for fragmentation files if u store the game in mechanical drive.
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
https://linustechtips.com/topic/889895-mouse-laggy-help/#findComment-10976867
1 minute ago, gabrielvis8 said:
i have ssd and cpu usage is 40%
If u remove the ram will it fix the problem?
https://linustechtips.com/topic/889895-mouse-laggy-help/#findComment-10976877
10 minutes ago, gabrielvis8 said:
lemme try reinstalling it
Dont re-install it REMOVE it.
Is it the same memory like the one u have installed or its a different memory from different brand and has different speed?
Try to tinker with the BIOS settings like enabling or disabling XMP or changing the ram timing.
https://linustechtips.com/topic/889895-mouse-laggy-help/#findComment-10976910
same and the ram speed was 2666
https://linustechtips.com/topic/889895-mouse-laggy-help/#findComment-10976915
how do i install it in dual channel btw
https://linustechtips.com/topic/889895-mouse-laggy-help/#findComment-10976920
If your motherboard has 4 dimm slot install the ram in the slot no 2 and 4.
https://linustechtips.com/topic/889895-mouse-laggy-help/#findComment-10976925
Just now, gabrielvis8 said:
For optimumperformance, when enabling Dual Channelmode with twomemorymodules, we recommend that you install them in the DDR4_1 and DDR4_2 sockets.
What is your mobo anyway?
Just read the bios POST message or download cpu id tool to check if the ram runs in single or dual channel
https://linustechtips.com/topic/889895-mouse-laggy-help/#findComment-10976933
9 minutes ago, gabrielvis8 said:
GA-A320MA-M.2
(rev. 1.0)
Check your manual *picture it says DDR4_2 is in the slot no 2 and DDR4_1 is in the slot no 4.
 i got 16gb ram before i removed it
U can get 16GB in single or dual or even quad channel.
https://linustechtips.com/topic/889895-mouse-laggy-help/#findComment-10976962
