Hello thanks for clicking on my post, I am having a little bit of a question here, I can't figure out which is better, so as usual I come to the awesome LTT Community to see if you fellow pc geeks can help me out. I am building a budget gaming/streaming/video editing pc (mostly gaming). I am wondering which case out of these two should I get.
Corsair Carbide SPEC-04 TGhttps://www.inet.se/produkt/6902438/corsair-carbide-spec-04-tg?gclid=Cj0KCQiA-qDTBRD-ARIsAJ_10yJXUH7UPZs3vVR-mvrSEbwd_PNDISZa6j_SjtqvNTIqhfpQkUQvcBIaAqBwEALw_wcB
or
Cooler Master MasterBox Lite 5 RGB: https://www.computersalg.se/i/3546306/cooler-master-masterbox-lite-5?gclid=Cj0KCQiA-qDTBRD-ARIsAJ_10yJUpRdsbBV9Jom4hoviJ5l2Tr75Ng3iJE3MjDiGjrntbRX1Gjc3GdsaAv1rEALw_wcB
Now I have already decided between these two cases, so please DON'T TELL ME TO GET A DIFFERENT CASE. I am aware that the MasterBox has less airflow but for me to decide if I want a case or not, there has to be MORE THAN JUST ONE DECIDING FACTOR. The MasterBox comes with all 4 fans pre-installed with an actual tempered glass side panel if you get the RGB edition which is what I am going to pick if I go with the Cooler Master one. The Carbide is cheaper and has more airflow but does not come with all fans pre-installed and I HAVE TO HAVE ALL  AVAILABLE FAN SLOTS FILLED WITH FANS meaning I have to buy extra fans which brings the cost to the same as the MasterBox anyway. The Carbide does have tempered class if you go with the TG edition which I am if I pick the Corsair one. But the Masterbox has RGB... I just Don't know!
https://linustechtips.com/topic/889455-cooler-master-vs-corsair/
If you plan to use a liquid cooler, the MasterBox Lite 5 has better support for it. The I/O placement on the Spec-04 is a little weird as well, since it is on the side of the computer that will likely face away from you.
I am using Fans that why I said in my post I want all fan slots occupied with fans, not water cooling, I don't have money for that.
or
one thing that i like to take into consideration when picking out a case is the customer support for the company.  I know it sounds stupid but you never know.  Corsair has some of the best if not the best customer service that i have ever dealt with and its a pretty long list while cooler master on the other hand is the complete opposite.  There is pratically no way of getting a hold of them.  While it may have changed since i dealt with them, i know corsair is just great.  So if customer support is important to you, then go with the spec-04
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
46 minutes ago, Legendarypoet said:
The Masterbox shouldn't be too bad if you're only planning to push it to 3.8. I don't like the Spec-04's internal layout so the Masterbox wins in my opinion.
Thank you, I have bought the MasterBox, so cool.
