Hi, I've been learning a lot of javascript recently and I began programming a script that would emulate how your starting stats are rolled in Dungeons and Dragons. I've never actually played d&d, but from what my roommates were telling me, your starting stats are acquired by rolling a 6 sided dice 4 times (or rolling 4 six side dice all at once) and then taking the highest three numbers and adding them up together. I programmed that like this:
function diceRoll(min, max) {
    return Math.floor(Math.random() * (max - min + 1) + min);
   var rollSet1 = new Array();
    rollSet1[0] = diceRoll(1, 6);
    rollSet1[1] = diceRoll(1, 6);
    rollSet1[2] = diceRoll(1, 6);
    rollSet1[3] = diceRoll(1, 6);
This simulated rolling the 4 dice.
var set1Smol = (Math.min(...rollSet1));
This set the variable: "set1Smol" equal to the smallest number out of the 4 numbers in the array.
var stat1 = (rollSet1[0] + rollSet1[1] + rollSet1[2] + rollSet1[3] - set1Smol);
And this set the variable: "stat1" equal to the sum of all 4 numbers in the array - the smallest number in the array.
I did this for each of the 7 rollSets and put the "stat(x)" variables into a separate array, and then used the Math.min operator to find the smallest number out of all 7 stats.
var totalSetSum = new Array();
    totalSetSum[0] = stat1;
    totalSetSum[1] = stat2;
    totalSetSum[2] = stat3;
    totalSetSum[3] = stat4;
    totalSetSum[4] = stat5;
    totalSetSum[5] = stat6;
    totalSetSum[6] = stat7;
   var lowestStat = (Math.min(...totalSetSum));
Now the one thing I couldn't figure out was how to get rid of the smallest number in the totalSetSum array. Right now I have it just printing all 7 stats and then telling you which one is the smallest, but what I would like to do is create a character stat object with 6 properties that are equal to the 6 highest out of the 7 stats. Does anybody know how I would go about programming that? Any help would be appreciated! Thanks!
Here is a link to my github where I have the full javascript program located.
Pseudo code (not really javascript, just translate it over):
var index = 0;
for (i = 0; i < totalSumSet; i++)
	if (totalSumSet[i] < totalSumSet[index])
    	index = i;
totalSumSet.Remove(i);
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
var index = 0;
    	index = i;
In JavaScript you use splice.
totalSumSet.splice(i, 1)
https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/splice
That being said your code would remove everything smaller that the first item.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
I created a fiddle for you. https://jsfiddle.net/ej8bjpmv/
Open the console in your browser and press run.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
How so? It only removes one item. You seem not to have seen that it is pseudo code and not js that I wrote. It's not meant to be taken literally as js and just copy-pasted. The translation process from concept to code helps newer people learn by doing.
var index = 0;
        	  index = i;
Pseudo code with brackets. Only removes the smallest item.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
