I'm hoping that someone might know what's going on because searching on the internet is not working. I have both of my monitors plugged into my graphics card (Nvidia 980ti). My right monitor is an Acer connected with an HDMI and the left is an Asus connected with a display cable. This setup has been working for a while but when the driver updated to 390.65 suddenly everytime I turn on my PC my left monitor isn't being detected. I've been having to uninstall the driver and reinstall it everytime I turn on my computer.
does anyone have any idea what could be happening?
https://linustechtips.com/topic/885054-980ti-dual-display-problems/
are you uninstalling with DDU when you do that?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
perhaps just a broken driver...
try to remove it using DDU, then get an older version. Like the one you had installed before.
If this doesn't help, well the 980 could have a defect, the display, or the cable...
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
I tried the DDU and it still does it. The only solution I have now is to unplug the monitor for a second whenever I turn on my computer and then plug the monitor back in. I was wondering, since this happens every time I turn on the computer, if it is a setting in the bios or something that I can change? I'm new to pc world and haven't really messed with motherboards and boot systems before.
