I have a gigabyte ga-h55m-sh motherboard, I can easily boot off a 3.5 hdd but I removed the hdd from the laptop I use a lot and tied to boot off of it and the system just shuts down and restarts. Has anyone had this problem before? When I boot off the 3.5 inch drive I can access files from the 2.5 inch one but for some reason cant boot off of it. Would I have to wipe the drive and re-install the OS with the desktop?
https://linustechtips.com/topic/8826-25-hdd-booting-problem/
It Could be that the OS Drivers installed on the 2.5 inch drive is not compatible with the gigabyte motherboard, you did state that it was removed from a laptop.. so it is trying to load the laptop hardware drivers, which is failing.
If you want to use the 2.5 in in your desktop, format it.
https://linustechtips.com/topic/8826-25-hdd-booting-problem/#findComment-98803
