I’m updating my bios to uefi and I’m doing this with the efi flash tool and I’m in dos on the screen that says “gigabyte bios to uefi update utility v1.07 flash type mx25l3205a and it says writing (kB) 2576 and it has stopped st that and nothing has happened in like 10 minuets it that normal should I continue to wait or does that mean it’s done and I should reboot
-My System-
Ryzen 5 1600X(@stock) | AMD Wraith Prism Cooler | 16gb Ballistix Sport Ddr4 (@2666mhz) | XFX GTS Black Edition RX 580 8gb |
Asus B450M-A Motherboard | 500gb 840 Evo Ssd | 550w evga N1 Power Supply | Vivo Micro Atx Case
-Peripherals-
Acer KG1 1920x1080p 75hz FreeSynce Monitor | Red Dragon M601 Mouse | Red Dragon K55 Keyboard |
Logitech G430 Headset | FiFine 669B Microphone | Logitech Z323 Speakers |
PcPartPicker Link
https://linustechtips.com/topic/881387-i-need-help/
Do not reboot, I believe it should reboot itself. Powering down the system while flashing the BIOS usually results in dead boards.
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
https://linustechtips.com/topic/881387-i-need-help/#findComment-10894453
Ok I won’t but how long does it take
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881387-i-need-help/#findComment-10894456
Flashing a BIOS should not take long. Take a picture of your screen and upload it so we can see what you're seeing.
https://linustechtips.com/topic/881387-i-need-help/#findComment-10894459
Probably varies by board and BIOS.
https://linustechtips.com/topic/881387-i-need-help/#findComment-10894462
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881387-i-need-help/#findComment-10894466
1 minute ago, Crunchy Dragon said:
Probably vaires by board and BIOS.
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881387-i-need-help/#findComment-10894468
I found a really crap video of someone using v 1.07
As you can see, it will tell you when to reboot. It looks (obviously) like yours is stuck.
EDIT: @megamastermike01 If the freeing continues any longer, while knowing the possible risk, you should unplug and reset the CMOS.Gigabyte boards have a dual-bios to protect against this causing damage.
https://linustechtips.com/topic/881387-i-need-help/#findComment-10894482
I rebooted and the bios is fine it still has version f13 on it and I’m not doing that again lol almost lost a 100$ motherboard
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881387-i-need-help/#findComment-10894561
You might have just dodged a major bullet. I don't update my bios unless there are compatibility issues (CPU or RAM) or there are stability issues. Or other major fixes, but that is on a case-by-case basis. It's just not worth the risk IMO.
https://linustechtips.com/topic/881387-i-need-help/#findComment-10894574
