okay so I recently built a new pc, before that I had a laptop with an extra monitor attached via vga, I built my pc and used the extra as the only monitor using a dvi. in the game stick fight I started noticing lines that start at the bottom of the screen and going up. then in many other games like pubg I notices that if I move the camera fast then I kinda see a similar effect, not as noticeable but there and annoying.
an imgur link to a 4 second video showing it on stick fight: https://imgur.com/a/xXo3L
I believe this is the monitor because when i take screenshots through steam they don't have the issue. what could the issue be? i have some other monitors in the house that i can try. I'm also hoping its that because I already had to return the last card due to it being bad.
my build incase it matters. the monitor is a refurbished dell that we have had for years.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($197.15 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($60.98 @ Newegg)
Memory: Patriot - Viper Elite 8GB (2 x 4GB) DDR4-2666 Memory ($104.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($46.77 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1060 3GB 3GB Windforce OC Video Card
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case ($59.99 @ Newegg)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($46.99 @ Amazon)
Wireless Network Adapter: TP-Link - TL-WDN4800 PCI-Express x1 802.11a/b/g/n Wi-Fi Adapter ($39.88 @ OutletPC)
Total: $556.75
Generated by PCPartPicker 2018-01-02 15:03 EST-0500
note: I didn't notice this issue when I was using it with my laptop, but I also never played games on that monitor to know. Thanks in advance
oh and I guess what is some good gaming monitors for near or below $100, 20''+ preferred, and idk if there is a way to get 144hz in that range.
https://linustechtips.com/topic/880743-display-issue/
Turn on VSYNC in games and see if that solves the problem.
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
https://linustechtips.com/topic/880743-display-issue/#findComment-10888215
Just now, veltoc said:
where is that? my panel is oddly limited in options
VSYNC can also be an in-game option.
It locks a game's framerate to your monitor's refresh rate or half, quarter, third, etc your of monitor's refresh rate. Tearing occurs when the panel trying to display multiple different images at the same time because of the refresh cycle.
https://linustechtips.com/topic/880743-display-issue/#findComment-10888241
