I currently just bought a uDac 3 since at I was mainly going to use it for usb audio. I think I have terrible shielding on my motherboard. Now, I am interested in the sennheiser 6XX. A udac3 will not be able to power it properly. Any solutions?
Someone recommended that I keep the uDac and buy a schiit Magni 3 amp. But can I use the uDac 3 as a dac only? I believe the uDac amp will be on no matter what. Or does it not matter if I have the amp from the udac and the amp from the magni on at the same time?
Or should I just sell the uDac 3 and buy a modi/ modi Uber? I mean... Who would even buy a uDac 3? Doesn't seem very popular.
Thank you
https://linustechtips.com/topic/880476-dac-and-amp-help/
I have the uDAC 3 from NuForce, it's a nifty little DAC combo, I'd suggest you try it with the HD6XX first to see if you can power the can to loud enough level for you before committing more cash and time to acquire the Schiit stack. Yes, the uDAC3 can be used as a dedicated DAC as it has a pair or analog (L/R) outputs at the back. It's capable of 24bit/96 kHz which qualifies it as HiRes (according to Sony). I don't use the uDAC 3 much as it's more of a laptop DAC combo for me....full sized desktop audio gear is where I'm at!;)
One thing though, the HD6XX scales well with higher end audio gear, so getting a Schiit stack (or other higher quality combos or stacks) might reap some appreciable audio benefits  with the HD6XX.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/880476-dac-and-amp-help/#findComment-10885765
Okay, I'll definitely give it a try. I was just thinking of the numbers in my head, and doubted that a USB port could provide enough power. I do believe I can provide more voltage through the bios (gigabytes usb dac-up stuff) but at the same time, don't want to fry anything.
And if that doesn't work out, I can use the uDac as a dac only and just get a Magni 3 for now and find a better dac sometime in the future.
I just want to clarify, the amp portion for the uDac is only working for that 3.5mm jack up front? Coaxial would just be preamp, and the analogies would be preamp and dac? Just trying to understand how all this works.
https://linustechtips.com/topic/880476-dac-and-amp-help/#findComment-10885877
