Hello, I have decided to upgrade my audio for myself/when speak on discord/skype etc. But mostly for me because audio is important for me and I like the control over all of the volume. my budget is around 100 to 300. Would like to keep it around 200 but I will settle with 300 if the equipment is good. I'm looking for a Condenser mic like Audio-Technica AT2020 I will most likely go with that mic. But suggestions are welcomed. Next thing is I would need a mixer does anyone have a suggestion on a good mixer? that gives me wiggle room to do stuff with? Thanks for reading and I can't wait to hear your guys response .
This is the audio setup I have now. Let me know if I should change something or not?
Microphone: https://www.amazon.com/Audio-Technica-AT2020-Cardioid-Condenser-Microphone/dp/B0006H92QK/
Mixer: https://www.amazon.com/Behringer-1204USB-BEHRINGER-XENYX/dp/B00871VO5Y/ref=sr_1_7?ie=UTF8&qid=1514840638&sr=8-7&keywords=behringer+mixer
Cables: https://www.amazon.com/gp/product/B00GYGRTT4/https://www.amazon.com/gp/product/B005HGM1D6/?th=1
https://linustechtips.com/topic/880344-upgrading-my-audio/
