Hi,  I'm new and haven't had any previous account. At the time being; I'm working on a scratch assembly.  I found a killer deal on EBay and had to have(36 lot cpu{2gh and four core}. That being the case; though, rest is mundane.  Almost every dollar I spent went to charity and processors used(still a good deal,  ja?) While my tech skills are par; I'd really appreciate help with power supply. The lanky ones I have have a little bit of the board sticking out. What cables do I need? Thanks
https://linustechtips.com/topic/879625-psu-edge/
If those are server power supplies, that bit of board poking out is meant to connect to the motherboard directly(provided you have an actual server board).
Welcome to the forums!
https://linustechtips.com/topic/879625-psu-edge/#findComment-10877774
